Hello Boyd.
Where did you get the safety loop from? I see it in pictures above. Seems pretty solid and bolt on, right?
Martin
Hello Boyd.
Martin
Yep, very solid, bolt on and quite adjustable, too. I got in on a group buy about 2 years ago, dont know if they will have any pre-made, but please check...
Metco motorsports
Factory 5 driveshaft safety loop
Hi Boyd. On those CNC reservoirs, check them with a magnifying glass. I had one that had a flaw in the casting, and it took a while, but started seeping right through the bottom surface. Also, there's not much "meat" to screw those pipe fittings in to, so don't go too crazy on tightening them up.
Pet the dog.
