Results 1 to 40 of 51
Thread: The new coupe race nose on a Gen II coupe
    Senior Member jkrueger's Avatar
    DFW, TX
    I wanted to post about my install of the new FFR coupe nose on my Gen II Daytona. I quick background on my car. I finished it in 2013 and my Dad and I raced it in the One Lap of America race twice and did quite well with it. It has been used mostly as a track car but was road legal as well. Late last year I decided I wanted to wheel to wheel race it and started working on mods that would help it be competitive in the NASA ST2 class. Part of those mods was a new aero package to increase the overall downforce on the car. I installed a APR wing on the back and when FFR announced this new nose and splitter I thought it would be perfect to help balance out the car.
    The box came via truck freight and was well packed
    Out of the box it fit the contour of the Gen II coupe perfectly. The new radiator opening fits perfectly and snugly into the original opening.
    The carbon fiber splitter is beautiful!
    I decided to move the splitter more forward. Since this a race car, I'm not worried about street clearance (just clearance getting it on and off the trailer. This is 5 inches exposed from the front edge of the nose.
    I trimmed off the sides. I am going to make this removable with Dzus connectors. If you were going to permanently attach the new nose to the car the sides would help you blend into the fenders.
    The big issue with the new nose and splitter is how do you open the hood. John George came up with a good idea using a BMW E30 hood hinge (see his build thread). I came up with a couple of ideas as well. Making it removable, I can pop it off in the pits and then open the hood normally. I will make the brake duct hoses (and any wires for lights) slightly longer to accommodate this. I also thought I would make some wood blocks to place under the wheels to raise the nose up high enough to allow the the hood to tilt with the new nose and splitter attached.
    I will post my progress here as I go along.
    http://www.25tires.com
    Nashua, NH
    looks sweet! how far out did you set the splitter?
    http://johngeorgeracing.com
    DFW, TX
    Hi John
    I think I am going to start at 5 inches for no particular reason. Maybe Jim Schenck can chime in on what he thinks would be a good starting point. Where are you going to start with yours?
    JC
    Mark Dougherty's Avatar
    Hershey PA
    Hi JC
    we are starting at 3.5 with Johns
    this way the nose will still open
    The traveling Builder
    717-773-5624
    Hershey PA
    Looks great by the way
    717-773-5624
    Gorham, ME
    Nice addition to the car!!
    are you painting it in the body color?
    DFW, TX
    Quote Originally Posted by John Dol View Post
    are you painting it on the body color?
    I am going to paint it. I'm going to start working on it tomorrow.
    JC
    Senior Member smithtlw's Avatar
    Brockport, NY
    Very cool to see it on a gen 2 coupe! I really like the looks of it and the fact that it is functional is great.
    That splitter will make a huge difference on the track, great work.
    Senior Member HCP 65 COUPE's Avatar
    NORTH CENTRAL CT
    If you install air jacks then you can open the hood easy while on the jacks just an idea.
    DFW, TX
    Quote Originally Posted by HCP 65 COUPE View Post
    I like your thinking. I actually thought of putting air jacks on the car when I built it. They are pretty pricey though.
    JC
    Inspiration:
    DFW, TX
    I am almost done with installing the new nose on the car. Today I installed some abrasion resistant plastic on the underside of the splitter to try and make it a bit more durable. Last week I sprayed the nose with filler/primer and today I was doing the final sanding on it. I hope to paint it tomorrow if the weather permits. Then all I need to do is install the dzus fasteners and the splitter supports.
    Brake ducts
    Not the most ideal position for ducts. I'll put a scoop on the outside if I'm not getting enough air to the brakes.
    I loved my Ap racing air jacks. I ran some aluminum 1/2" (3/8?) pipe to the rear of car and then used a quick disconnect to attach a divers compressed air bottle. Worked great!
    Nashua, NH
    where did you get the plastic that you used under the splitter?
    Hershey PA
    lol
    717-773-5624
    DFW, TX
    Quote Originally Posted by johngeorge View Post
    McMaster Car. It is called UHMW. It is suppose to be very abrasion resistant.
    https://www.mcmaster.com/#uhmw-polyethylene/=16i00iq
    DFW, TX
    Paint is done.
    NORTH CENTRAL CT
    I have seen some folks use regular single acting air cylinders for air jacks before but i never have so no clue how safe that is and you would have to make your own safty stands. Might be a fun project to try or explore.
    Pittsburgh, PA
    Great work, and keep the pictures coming please! I'm interested in hearing how this changes front end grip compared to the last setup, which I recall was a modified piece from a C4 Corvette. Also, isn't it nice to not have to scratch-build that thing?
    Member Owlknight360's Avatar
    KY
    Silly question, but did you just call FFR and order the nose by itself? If you don't mind me asking, what did it cost? (Same questions for the splitter)
    DFW, TX
    Quote Originally Posted by Owlknight360 View Post
    Yes, you can call FFR and just order the nose/air dam and the splitter. You will have to call FFR to get the prices. They gave me deal so I don't know what the retail prices are.
    JC
    Brockport, NY
    So, I call and ask for the JC coupe splitter special?
    DFW, TX
    Nose is all done. I'm going to the track this weekend. I'll report how it performs.
    Gorham, ME
    That looks sharp.
    Are you going to duct the air intakes to your brakes at later date?
    Brockport, NY
    I am also curious so I called and got a quote. I assume that they gave me retail prices as they didn't know me nor did I ask for the JC Special. To get the nose/splitter to my door would be a tad over $1K - shipping is a significant part of the cost. He did not give me a separate cost for the 2 components. For the amount of time and effort you would have to invest to come up with something similar I don't think the cost of the well done FFR piece is too bad.
    It really does add a sense of modern/serious race car look to the classic shape.
    Do you happen to know what the material is JC?
    DFW, TX
    Quote Originally Posted by smithtlw View Post
    The nose is fiberglass and the splitter is carbon fiber.
    The race splitter for the 818 is $550, so I would image that the coupe one is similar in price. It is probably a couple hundred to ship the nose (not heavy, just bulky), so that leaves around $200-250 for the nose?
    DFW, TX
    That looks sharp.
    I think I am going to have to. I'll get that done before my April track date.
    JC
    Nashua, NH
    Quote Originally Posted by jkrueger View Post
    What do you have planned for the rear of the car? With that much front downforce you will have severe oversteer having unbalanced aero.
    DFW, TX
    I put a AFR GTC-200 wing on the back.
    JC
    Nashua, NH
    JC
    Ohh!! that will fix the unbalanced aero lol. Any pics of how you mounted it? just curious
    DFW, TX
    This is a temporary mount. Once I know my angle is set correctly, I'm going to get a one piece upright made.
    DFW, TX
    Took us an hour to figure out what combo of ramps were needed to get the car in the trailer without hitting the splitter. I think I may try to figure out a way to remove the nose/splitter and hang it up out of the way when loading and unloading the car.
    Nashua, NH
    bmw e34 hood hinge!! its what we did (well, we used e30, but e34 hinge is 2" shorter and will fit between the foglight buckets and not cut as much as we had to)
    it pops up the nose by 3" and that will give enough clearance to load in/out of trailer and open nose with splitter on.
    DFW, TX
    When you get a chance. I'd like to see some pictures and details of that mod. Sounds like a great solution.
    JC
    DFW, TX
    I promised some full car pictures when I got it out so here they are.
    Nashua, NH
    That looks wicked!! Awesome JC!!!
    Gorham, ME
    Awesomeness!!!
    That looks fast sitting still
    JC-
    What a great job on the new splitter and nose! She looks terrific! I agree with John, she looks fast standing still.
    Thanks for sharing!
    DFW, TX
    It is late and I loose an hour of sleep tonight so this will be quick.
    The car did great today!
    I kept increasing the rear wing angle every session and it was helping the oversteer in the high speed exits but it was still loose on exits in slow speed corners. A friend suggested adjusting the pan hard bar height and that made a huge difference in the car. Now it is pretty neutral in the slow speed corners and only slightly loose at the exit of the high sped corners. Thanks Ian. I’m going to continue to adjust the wing tomorrow to see how much angle I can put on it. The car has a lot of grip, from a combo of the stickier tires (Toyo R888) and the nose/splitter and the wing. My corner speeds (especially the higher speed corners) are up a lot compared to where I have been before and it really shows in my end of straight speeds.
    The full floating rear axle that caused so many head aches worked great (other than the vent). I am very happy to say that I have no more pad knock back. A huge improvement!
    The 3.73 rear gear (used to be 3.31) really woke up the car. It is amazing how it pulls, and the third to fourth shift puts you in the back of the seat.
    It will take me awhile to get through the video. I'm out of town for work next week so I need to focus on that, but I will try to get something posted.
    I also got moved up from HPDE 3 to 4.
    JC
