Are you guys using RTV? Or the Right Stuff? what sealant should I be using
This is what I use without fail - Permatex® Water Pump & Thermostat RTV Silicone Gasket Maker - See more at: https://www.permatex.com/products/ga....ERj9guV9.dpuf
I used the Permatex and the Right Stuff on different tries. They both worked fine but the Right Stuff had a short working time and also was much harder to separate upon removal. I actually bent the backing plate pretty good trying to get it free. I would probably use the Permatex next time.
