Thanks Thanks:  6
Likes Likes:  7
Results 1 to 40 of 285
Thread: Ducky2009 MK4 Build #9035
Threaded View
  1. #11
    Lilburn, GA
    Heater
    Was sick last week. Finally got back to work on the car. Heater is installed. Made a bracket to hold a 4-way valve and ran the FFR control cable through the firewall. Now I can circulate the water to the heater core, or shut off the heater core and still have the required recirculated water to the engine. Still need to made and add the restrictor into the hose. Made a bracket and installed the fuel tank vent. Also added a support bracket to the air filter. I felt like the filter was a little shaky. After installing the wiper motor I discovered the casting was cracked. Courtnie is taking care of me on this one. I made the glove box door today. Need to install the hinges and latch. Next step, pad the dash and add the leather.... Then the gauges. Still thinking thru the diode (RT turn signals) attachments. Thinking about making a plexiglass "insulation" box. To be continued...
    Heater 4-Way Valve Bracket.jpg Heater Hoses Installed.jpg Heater Control.jpg Fuel Vent Bracket.jpg Air Filter Bracket -2.jpg Air Filter Brkt Installed.jpg Wiper Motor Cracked.jpg Fuel Tank Vent.jpg
