Shifter cables http://www.boatersland.com/telccx43307.html
clamps http://www.mcmaster.com/#2695k85/=w3ugmq
At transaxle: 4 inch bell crank for "twist" motion with 3/8 OD, 1/4 ID oilite bushing from Ace, cut stock FFR shift bracket vertical mount for twist, used horizontal for pivot for bell crank, modified the bulkhead tab for in/out replaced tab with two holes for clamp listed above, mounted clamp for twist through bell crank in 2 x 2 x 1/8 aluminum angle mounted under FFR shift bracket. Used 1/4 - 28 female rod ends and FFR provided ball stud ends where appropriate. My FFR bracket is shifted 1.5 inch forward and my shift arm is flipped so the bracket is forward and it is welded to the shift coupler.
At Shifter: Drilled MR2 shifter for 3/8OD, 1/4 ID oilite bushing, shortened as required. Cut off peg from stock twist motion arm, drilled for 1/4 through hole. Used 1/4 -28 female rod ends to connect to cables. Cables clamped with McMaster clamps listed above. Hung shifter ball socket 1/2 under plate to limit up angle on cables.
http://thefactoryfiveforum.com/showt...-Thread/page27 post 1043 for pictures etc
note, finding my old posts mine are 7 feet NOT 8" sorry
