Halibrand wheels on basic roadster
I am building an Mk4 Roadster basic kit using a 1996 mustang donor. the Rolling chassis was completed a few months ago. The body, doors, hood, trunk and dash are mounted. All gauges work. I'm shopping for new tires now.
Factory five included a set of Halibrand 17" rims, 9" for the front, 10.5 in the back. the build manual, and the FF tech guys, say that if you use these wheels with the stock mustang lower control arms, they will rub on the control arms. Ive been told that you can use them if you limit the turn radius.
Has anyone used these Halibrand rims with the stock mustang LCA's? Is the reduced turning radius a problem? Or should I just go with the stock mustang rims and new 17 x 8 tires.
any suggestions and insights will be appreciated
