Would like to see what people with A50XS coyote are doing about air intake and what MAF housing you are using?
Also interested
'33 Hot Rod
MK4 Roadster
Me too, some day.
Talked to ford performance and they recommended the 123mm MAF housing
I have an A50XS in my car. However, I just couldn't cleanly make the packaging work on the 123mm MAF housing. I ended up fabricating a custom 100mm MAF housing. You may be able to make the Ford Performance part work but would probably have to cut down the end to shorten it up or custom route the intake path to some alternative location in the engine bay. Here are a few picks of the CAI I fabbed to give you a general idea.
