AZPete
Doug, a good idea. Can you tell me the dimensions of the two thicker pieces and the 7 thinner pieces?
All the parts are 1.5" wide. There are actually 3 heights because they mount to different surfaces. The goal is to produce an even surface about 3/4" below the lowest mount point, the body at the side.
- The 3 front parts that mount direct to the chassis are 0.88" tall
- The long parts along the rockers that mount to the body are 0.75" tall.
- The two parts at the rear that mount to the engine frame rails are 2.44" tall at the front, tapering down to about 0.50" at the rear.
Let me know if you have more questions.
