Results 1 to 5 of 5
Thread: Carburator 101: Downleg vs Annular boosters on Holley and QFT carbs
Threaded View
    mcwho's Avatar
    DeBary - Florida
    I wish there was a section on engine builds in here.
    I have been doing research on which of these are best for Street Roadsters with a mild 33i cu in engine.
    Specifically 302 Stroker @ 331 cu in, Edelbrock Performer Rpm Heads, RPM Air Gap intake, MSD Distributor, current carb is a Edelbrock Thunder 1806 AVS carb, 10-1 comp ratio, and Cam spec is: Hydraulic Roller 224 intake / 234 exhaust* @ 050 duration.* .542 / . 562 Valve Lift
    For all the research I have read a few items such as Annular does not always work better than a downleg, I read that if you had a "cold intake" the Annular was better. I am building what I consider a daily street driver. I want reliability.
    Looking at the Holley an Quick Fuel carbs I have come up with more opinions to stay with downleg. I also have read that the Annular Hardware takes about 30 cfm away from a carb because of the hardware restriction.
    Based on what I have read so far, a QFT SS-650 is just a tad big for this engine but should work fine. This one had Mechanical Secondaried, Electric choke and downleg Boosers.
    Commpens? Opinions?
    Baghdad Bob
