0
0
Power Steering Question on 1997 Cobra Engine
I am using a 1997 Mustang cobra engine, original factory reservoir, Factory Five power Steering rack, no hydro-boost as I am using a Wilwood peal box. I am redoing the power steering lines and having some issues with the power steering pump. Does anyone know what size the threads are on the high pressure side of the pump? Also I am assuming the other side is just a hose clamp? If you have used this set up is a power steering cooler necessary while I am at it?
- You may not post replies
- You may not edit your posts
Forum Rules
