Results 1 to 17 of 17
Thread: 33 Hot Rods in DFW?
    Mar 2017
    33 Hot Rods in DFW?
    Are there any owners of the 33 Hot Rod ( prefer with a hard top ) in the DFW are that I can try to fit into?
    Mar 2017
    That doesn't list their forum user names, though.
    Oh, whoops, you're right! That doesn't seem very useful
    A question for http://thefactoryfiveforum.com/member.php?710-geoffav then - perhaps he can explain how to use it..
    I found a long-winded way to do it.. search that thread for the name you find on the map and you'll see who posted it..
    Senior Member dallas_'s Avatar
    Dallas, TX
    Look up WRP, he's local, pretty near you if I remember right.
    Let me know if you touch base, I'd like to go see his car too.
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
    Senior Member JOP33's Avatar
    Haslet, Texas
    I'm building in Haslet, but only a week in. Not sure there's much to see at this point!
    Mar 2017
    I know Haslet, my mother used to live in that area. Did you opt for the hardtop?
    Mar 2017
    I tried a user name lookup on WRP and came up empty. Hope he sees this!
    Quote Originally Posted by dallas_ View Post
    Senior Member H R Lucky's Avatar
    Jun 2012
    CrossRoads, Pa.
    here's a link to WRP's build thread: http://thefactoryfiveforum.com/showt...it-075-Restart
    just click on his user name and send him a private message.
    Nevin, AKA H. R. Lucky
    33 Hot Rod sn 524 build started 3/18/2013, First Start-5/09/2015, Go Cart-6/01/2015
    5.0 Coyote engine, 9in. Ford rear, 4 Link, Wilwood 12in. front brakes
    AC, power steering, FFR 17/18in. Hot Rod wheels
    Mar 2017
    I found him, pm sent, thanks
    I have a 33 Ford roadster. Your head isn't going to be the problem, if it is your feet won't fit. Sent you a PM/replied.
    Mar 2017
    My feet are always a problem Replied to your PM
    Haslet, Texas
    Quote Originally Posted by Mick_d View Post
    Yes, I did. Just now installing rear brakes...http://thefactoryfiveforum.com/showt...Mobile-1-Build
    Senior Member TDSapp's Avatar
    Frisco, TX
    So Mick_D what part of DFW are you in?
    Tim
    Mar 2017
    I'm in North Carrollton, just between The Colony and Lewisville, south of 121. Where are you?
    Frisco, TX
    I live in West Frisco and am just north of The Colony. My stage 1 Hot Rod gets delivered next month, you are welcome to drop by and check it all out once it gets here.
    Tim
