84
608
Went through tightening the brake and fuel lines then drilled and final (!) fitted all to the chassis.
Fitted the SBC motor - now I can see why they say "shorty water pump and pulleys" in the instructions - there's a 1mm gap between the steering rack and bottom pulley.
Oh well, that's unfortunate, I was hoping to use the ones that came free with motor.
Everything else fit well, including mechanical fuel pump.
motor-in1.jpeg motor-in2.jpeg motor-side.jpeg motor-side2.jpeg small-gap.jpeg
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
