0
0
Will H4 ECU work with the EZ30? **Edit: Topic Solved**
I know GM uses the same ECU for some of its 4 cylinder engines as its LS engines. Just attach the right engine and reflash the ECU and you good to go. How does this work for the EJ2xx and the EZ30? Can i use a EJ2xx ecu and reflash it to work with the EZ30? I see most people that use the EZ30 just use a standalone, but in my state this is problematic for registration and annual smog. It is much easier if I can use the stock ECU.
