0
0
Originally Posted by
Gromit
perhaps we have a clarification problem going on here... Collar up or down would be different depending on how you mount the KONI shock right? if you put the shock body on the bottom or top, then the direction you move the collar is reversed, for example shock body down then if you lower the collar = lower ride height, and conversely shock body UP, then lowering the collar = taller ride height.
I don't think anybody above has suggested which way they mounted the shocks and I think that would matter in this conversation.
Chris AKA Gromit.
You're very correct, Chris. My shocks are all shock body up, spring down. The collar is on top of the spring.
