RoadRacer
Since you're going for such pretty finishes, get the Kootenai bump steer kit..
Why do you say that, if I might ask?
JimLev
Looking at your pic I think you have those A arms on the wrong side.
Maybe it doesn’t matter or was there a recent change that isn’t in my manual?
Mastertech5
You're right. LCAs should be swapped side to side. The short adjustment part should be in the rear.
Y’all are exactly right. Someone pointed it out on Facebook also. I have swapped with around without marring my powder. A small amount of heat, an old nut and a big aluminum drift with a big hammer got them apart.
Correct now!
The whole chassis
And I put the brake pedal and MC in today piddling around. I think I have some painting to do before I go much farther and I need a new gun so might be a minute.
'33 Hot Rod
MK4 Roadster
Post Thanks / Like - 0 Thanks, 6 Likes
