Does anyone have a picture of their installation of the new style fuel tank filler with the softer rubber?
I don't have a picture but I cut a 90 degree off from the supplied rubber to connect the metal filler tube to the tank. I cut a section of the straight to connect the metal tube to filler cap once the body was mounted.
I will have to double check may have been a straight couple off the tank to filler tube. Either way you butcher up the rubber hose they give you.
No I didn't use the flare. Probably a good thing to point out in the next revision of the manual. If I recall the rubber hose is a shared part for the gtm we however hack it up.
Sorry for delay I just confirmed two straight bits cut from the wacky rubber bit. About 4 inches long from the tank to the end of the filler tube with a 90 bend and another 4ish inch section from filler tube to filler cap once body is installed. Clamp it on tight it's a tough spot to get to once you start adding engine and coolant tubes and brake lines don't want to have to fix a loose clamp on first fill up!
