Thread: Wiper Motor Wiring ?
    Jacob's Avatar
    Rogers, AR
    Does anyone sell a male plug-in that will match up to the female plug-in on the wiper motor? Seems like it would make a neater more fail safe way of making connections...thanks!
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    Senior Member Misterfubar's Avatar
    Olathe, KS
    Here is a cheaper option. Shipping is $7.50, but still saves a few bucks.
    http://www.britishwiring.com/Wiper-M...5.htm?CartID=1
    Ohio
    I have the plug from ********** on my Mk4. It comes with no way to lock onto the wiper motor. Had to put a tie wrap around it and the motor. If I had to do it over again I would just plug the wires onto the spade terminals in the motor housing and seal it with silicone. Easier and saves some money. If the plug came with a lock on it like all other automotive plugs have it would be worth it
    JRL16
    Mar 2017
    I did that with mine using the insulated spade connectors and potted it with silicone. Then put a connector on the end of the short harness.
    I do the same as Conger
    Jun 2015
    Fairfax Station VA
    Quote Originally Posted by conger View Post
    Do you happen to have a picture handy?
    MK IV Roadster #8631
