Results 1 to 14 of 14
Thread: Painting Transmission and Differential Housings - Best Products?
    Senior Member mach'er's Avatar
    Monroe, MI
    Does anyone have any tips for painting the aluminum housings on the trans and diff? Is POR-15 the way to go, even though it's aluminum?
    I'd like to paint them, and have time before my kit is delivered. I haven't decided between black, silver, or red - but definitely would like to do it. I'm concerned about adhesion and durability.
    If anyone has any experiences with POR-15 or other coatings for these applications, please let me know.
    Thank you,
    --Curt
    Jax Beach, FL
    Just a thought here. Painting those is also going to make them run hotter. They don't need paint for preservation. You can't see them unless you jack the car up, so what is the purpose?
    Senior Member RickP's Avatar
    Boyertown, PA
    I had mine powder coated in Kingsport grey.
    If you decide on black I'd recommend Eastwood Chassis Black. It comes in satin or gloss and is very durable. You can get it in rattle can or cans you have to mix and shoot with a gun. For these small items a rattle can would work well and these are no garden variety rattle can paint systems. The spray nozzle is about as close to a gun as you can get and if you want the top of the line product with ceramic it is a two-part system that comes in a special can with the activator built in to a separate chamber you have to release before shaking the can. There are primers especially formulated for aluminum. Aircraft and missiles are aluminum and most are painted. As for painting aluminum and it making the parts hotter do some research and you'll find that's not the case. Bare aluminum doest not emit heat energy as fast as painted aluminum. Google color and cooling and look for Colorado State University Little Shop of Physics for an experiment you can do yourself to prove it.
    Monroe, MI
    I know a guy that knows a guy. I'll call tomorrow, if I get a chance, and ask him about heat dissipation through a painted case. I don't believe it's an issue, but I'm not too proud to ask.
    RickP: Did the trans have to be disassembled to powder coat the case? That would be optimal, if I can just drop off my TKO and get that done.
    NAZ: Thanks for the info, and the research reference. If I go black, that sounds like it is a good option.
    Member unrealmach1's Avatar
    May 2016
    Woodhaven, MI
    I used the Eastwood Chassis Black on my 69 Mach1 and it worked great and still holds up after 7 years.
    Newbie Builder
    MK4 # 8947 - Base Kit - Coyote, TKO600, IRS - Delivered September 2, 2016
    http://thefactoryfiveforum.com/showt...V-Coyote-Build
    1969 Mustang Mach1 -393W, T5Z, Shaker Hood- Electric Pearl Blue w/ Stain Black Hood
    O'Fallon, MO
    You don't need special paint, Rustoleum is a great product
    Boyertown, PA
    Quote Originally Posted by mach'er View Post
    Yes it needs to be disassembled. Same with the rear. If powder coat is not an option, as others have said, por-15 or Eastwood chassis black is a great choice. If you want something besides black, rustoleum is a sturdy painted surface.
    Las t February I painted my intake w/ Rustoleum self etching primer and then silver Hammered rattle can paint. It still looks great. My valve covers are same except black color.
    Monroe, MI
    My bell housing is black, and as much as I'm tempted to go massive overkill on the red red red, I think I'm going to go with a good primer then the Eastwood Chassis Black to keep it less busy looking.
    I can say that after getting some input from someone I know, I'm moving forward with the plan to paint with no temperature concerns.
    Heart of Dixie, Alabama
    I had not even considered painting or powder coating either the trans or bell housings, but I like the idea. I think I will wash down both with carb cleaner and apply shark skin.
    Oct 2014
    Vermilion, OH
    Another vote for East Wood products,
    I used POR15 on both ... but I am not sure I would do it again! because it is a pain to apply and requires at least two coats plus some type of top coat. I will say it is durable and tough as long as the parts are properly prepped.
    The Eastwood products are great so far and I would probably go with that in a future build.
    Carl
    Kirkland, WA
    I used VHT Chassis Black, in the rattle can. I'm using the Rustoleum Hammered on my engine bay Aluminum - also a good product. You'll only see it when you're under the car.
