Thread: IRS Diff fluid question
    slpro1207's Avatar
    Moorpark, CA
    I have just filled my IRS differential that came from FFR complete kit. The book calls for 3.5 oz of friction modifier and 3.3 pints of diff fluid. I put in the modifier but the unit would only that a little less than 2 pints before running out. The car is on jacks and level. Any thoughts?
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Quote Originally Posted by slpro1207 View Post
    I assume you're talking about the newer 2015+ Mustang based center section. There's only the one fill port, on the back of the cover off center to the right about axle height. Mine took the recommended 3.2 pt (1.5L) lube plus 4.0 fl oz (118 ml) friction modifier before running out slightly. I can only guess yours must have had some fluid in it already.
    slpro1207's Avatar
    Moorpark, CA
    It is the 2015+ Mustang center section. Should I wonder what fluid was in it. Should I drain it and start over so I know what is in it and the levels are correct?
    That option is cheap and easy at this point vs the potential worst case. Probably you would be fine but do you really want to chance it?
    I agree the safe bet is to drain it and start fresh. That fluid lasts a long time. Get it right the first time.
    slpro1207's Avatar
    Moorpark, CA
    Good advise. Tomorrow I'm popping the drain plug and starting over.
    Ohio
    Mine came with some fluid in it so I drained it out. The recommended capacity in the manual seems to be a little off. When I put in what FFR recommended it wasn't full. My understanding is the fluid level should be at the bottom of the fill hole. Took a little more than FFR recommended.
    JRL16
    Mine came from the salvage yard full. But I am old, and it's heavy, so I suspected that somewhere along the line it would get tipped over and I'd have a big puddle under one of the axle holes. Once in the car I filled it. I used 80-90 Mobil1 gear oil like I always have in Ford clutch type lim slips. No additive. It works great and no noise. My theory is that what the additive does is make it slip and I don't want that.
