Results 1 to 11 of 11
Thread: Lower Control Arm Mounting Brackets Not Aligned
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Picked up Kit Friday evening and started the build yesterday AM. While mounting the lower tubular control arms we noticed the drivers side rear bracket mounting holes didn't with the forward bracket! Supposed to mount using the outside holes, appears the bracket is welded in a reversed position. Can only mount using outside of the front and the in side of the rear, technically looks OK but concerned this condition may create issues later in the build. Anyone ever had issues with this type of issue? Build is on hold until we talk with FFR tomorrow morning!
    pics would help?
    Longmeadow, MA
    pictures of correct passenger side & incorrect drivers side
    Longmeadow, MA
    O'Fallon, MO
    Thats a mistake, give them a call on Monday to find out how they'll resolve it. Thats too bad.
    Yep, looks like an error. Good news is that, since you will be using the outer holes, you can actually build it as is.
    Longmeadow, MA
    Spoke with FFR yesterday morning, they picked up the frame today, will modify and powder coat and back to me Fri/Sat this week! They really stepped up, build starts again this weekend! Great company!!
    Northern VA
    that is great to hear.
    wow good service from them. Not surprised though.
    Where do you live? You must be close to them
    Longmeadow, MA
    Western Mass, about 2 hour ride depending on traffic
    Senior Member brewha's Avatar
    Aug 2013
    Somers, Ct
    Quote Originally Posted by jwebb View Post
    Your lucky you are so close. I can't imagine starting the build and then have to wait again after waiting so long for it be delivered or picked up. F5's customer service has always been responsive and quick for me.
