Results 1 to 6 of 6
Thread: Front end alignment in Indiana?
    Jun 2017
    Hey guys!
    I'm located in Mooresville, IN and I need to find a shop that can do the front end alignment. Apparently, if the tech can't feed the year, make and model into the computer, they can't help me.
    If you want to bring it to Bloomington I can hook you up.
    Dave,
    Jeff is only 36 miles away. Most guys don't want to learn how to use their front end machines, so I'd be headed to Jeff's if I were as close as you. Google says it would take me 11 hours.
    Glen
    Coupe 0652 408 Windsor 510 hp TKO600-68OD 3.73 Traction-lok A/C and heat, Guardsman Blue with White stripes picked up 9/14 first start 7/10/15 go kart 8/15/15 registered, painted (body-on) 11/12/16 inspected and on the road 4/20/17
    Use Jeff's resources. x2.
    Jun 2017
    Thanks guys!
    Jeff,
    Send me a number or an address and I'll plan on driving down your way.
    Thanks again!
    Louisville, KY
    Jeff, anyone in the area you recommend for gear installs?
