Thanks guys, I PM'ed both of you.
MisterAdam
Also consider SDC's self cancelling unit, $75. simple to wire and also works the hazards. One flick for 7 second, 1 second hold for 20 seconds, 2 second hold for indefinite. One of the best things Jeff Kleiner advised me on....and there were a lot!
Eventually I'm going to install a Russ Thompson turn signal setup on the column. For right now I'm just trying to get the car on the road for a year of shakedown. I figure there are things I didn't do which I want, and some things I'll want to change. Anyhow, the RT setup will get installed when the body comes back off for paint in a year(or so....). The other thing is I'm using a dash for shakedown from a local builder that no longer wanted it. It already has several holes which I won't use when I install my own dash, but for now I need to put something in them. I'll have a couple "dead" switches already just to plug holes, but I definitely need a matching on-off-on switch for the temporary turn signals.
Thanks again!
-TJ
