Try using an online calculator like:
http://www.tremec.com/calculadora.php
You'll need to know your rear end gear ratio, the diameter of the tires, and the ratio of the gears in the transmission (if your's isn't in the list).
Thanks, I should have researched the forum first before asking the question. It appears that this rpm in 5th is somewhat normal; didn't know enough at the time of purchase to ask for a higher gear ratio so that I could use the 5th gear without fear of a speeding ticket…..
