The ECU does get "warm" but if it gets "hot" that would be bad. You should easily be able to touch it. EDIT - This only applies to when the Key is in the ON position, not when in the OFF position.
As mentioned above, check your grounds.
When we say to our customers "if there is anything you need, please ask," we mean it.
iWire Subaru Wiring Services
Over 100 Custom 818 Wiring Harnesses Built
http://www.iwireservices.com/factory...18-wiring-kits
[email protected]
