Results 1 to 11 of 11
Thread: Shift Console / Bezel?
Hybrid View
    Jacob's Avatar
    Rogers, AR
    So what is the story behind the round bezel and the oval aluminum panel opening? Did I get the wrong tunnel panel or do I need to find an oval bezel from a vendor?
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    No oval shifters or trim plates that I've seen. The oval cutout is to clear the various positions that different engine/trans combinations might give. There's a matching oval fill plate that you are supposed to use to fill after cutting to match your location. Mounted on the cover it disappears if using the kit provided carpet for the transmission tunnel. With vinyl like you've done, needs to be installed flush to look the best. A little late for you since you've already applied the vinyl.
    As an aside note, I see where FFMetals announced they will offer a transmission tunnel cover (1) without the cutout and (2) from slightly heavier gauge aluminum. Good idea on both accounts.
    Jacob's Avatar
    Rogers, AR
    thanks, its just vinyl so, I have plenty more. Guess I'll take a couple of steps backward? Shouldn't be too hard to fix.
    Levy 306
    T5
    2015 Mustang IRS
    Quote Originally Posted by Jacob View Post
    That occasional taking two steps backwards during the build, is actually standard procedure. If you don't do it once in awhile, you must have missed something..
    So. Bay (So. Calif.)
    I made two plates, one to fit inside the oval hole, the other to hold that piece to the trans tunnel top. I did my best to have the finished round hole centered over where the transmission shifter is located, so in the pictures both pieces look non symmetrical and skewed, which they are. It all sits flush with flush-head pop rivets.
    Jacob's Avatar
    Rogers, AR
    Quote Originally Posted by boat737 View Post
    I sorta did the same thing after I realized (should look at the directions,but I didn't)....just another small hurdle!
    Levy 306
    T5
    2015 Mustang IRS
    Wait... There are directions? I must have missed those too.
    Santa Clarita, CA.
    Go to ffmetal.com
    They now offer a new transmission tunnel cover with no hole cut out using .06 thick aluminum. Will be perfect for you.
    Quote Originally Posted by CDXXVII View Post
    Go to ffmetal.com
    You beat me to it! I can attest to the quality of the FF Metal products as I just received and installed their under trunk battery box.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Santa Clarita, CA.
    I made my own out of .06 aluminum similar to ffmetal.
    Woodstock ,Illinois
    Just an idea... you could bond a piece of thin plywood, radius the edges, and apply the vinyl. You'll have your hole where you wish, and it will be flush.
