I have a rather large 2 piston compressor and tank that replaced an old smaller unit several years back. When I installed the new compressor I added the auto drain to it, and it's a must have hear on Cape Cod with the high humidity. Also helps keep the air tools running better and is a must have if you are spray painting. Not cheap, but overall a good investment.
