If you also have roller rockers ala Harland Sharpe etc they are not silent. If not and this is a recently built motor there will be some valve train noise initially that will quiet down once it has been run in. It would also be a good idea to go back and re-set lifter preload. I prefer doing this hot with the engine running, but can be messy if you're not well prepared.
Franl
