Results 1 to 18 of 18
Thread: Trans Tunnel carpet question!
    Senior Member RickP's Avatar
    Boyertown, PA
    Not sure why my photos are being rotated during upload but nonetheless....... I've spent quite a bit of time fabricating the trans tunnel top which I plan on wrapping in the same material I did the dash in. My question is in the details of the last pic. If I wrap the cover (glue) over the edge of the rear lip, will I have interference of any kind when I install the carpet piece back there?
    My fear is if the tunnel top rests on top of the carpet, the rear lip may bend and create a unsightly wrinkle in the cover, which is a vinyl material. A small detail but I would like to cover the top now while I have time and not have any worries after I install carpet (which is a long way away from now).
    rear lip of tunnel top
    If the vinyl is firmly glued to the cover (e.g. 100% adhesive coverage) it shouldn't wrinkle if the aluminum should deflect a little when pressed into place. The vinyl should just flex. Once you get the carpet in place, you can trim the pile on the carpet where the cover contacts it. That will allow it to sit down pretty well.
    I wrapped my trans tunnel top and had no issues with its interaction with the carpet. I'm not sure of your install plan but my carpet was on the back wall area first and then I did the final install of the trans tunnel over it.
    Boyertown, PA
    Thank you gents. I shall press forward.
    North CT
    Where did you get the cup holders?
    Boyertown, PA
    Quote Originally Posted by chmhasy View Post
    From Eddie motor sports. They are billet aluminum anodized clear- medium. Fits a 3" hole.
    Norton, MA USA earth
    I know this isn't an option for everyone. If I cover the tunnel with anything but carpet, I make a new one that is wider by about 1/2 inch. Then I carpet up to the top of the tunnel. Then the cover can slip over the carpet hiding the raw edge.
    Boyertown, PA
    Hi Mike. I think you may have addressed another concern I have. I saw somewhere someone did the same thing and when the cover was installed over the carpet where it meets the tunnel top edges, the sides of the tunnel looked bowed out. I don't have the skill or tools to make my own tunnel top (this one is FFMetals no hole offering) but my thought was to run the carpet just short of the tunnel top and finish it with a carpet edging. Not really clear in my head how that will look though.
    Quote Originally Posted by RickP View Post
    I wrapped the FF supplied transmission tunnel cover on my #8674 build. So cut the provided tunnel carpet and had edging sewn onto three sides. Gives a clean look. Shows pretty clearly on these pics from final assembly.
    Boyertown, PA
    Oh wow Paul, that looks very nice. Did you have the carpet edging professionally done? The aft edging really ties the whole transmission tunnel top to cockpit in very nicely.
    Thanks. Yea, I'm happy with how it turned out. The cloth edging was sewn by a local auto interior shop. He recommended that material because it closely matches the edging on the FF floor mats. All ties together nicely. He also did the pieces by the door sill so that raw edge is covered as well. Visible in both of the pictures.
    I like how this ties into the dash. Very nice.
    I had planned to do my tranny cover in vinyl to match the dash as well. I was warned by another builder, that black vinyl can get extremely hot. It can be sticky hot and uncomfortable, as you tend to rest your arm on it. Not the case with carpet.
    Just thought I should mention it..
    Boyertown, PA
    Yeah, I've given that issue some thought. No doubt vinyl gets hot in the sun. I plan to apply heat barrier underneath and some padding on top but no doubt it will get hot. How hot? Time will tell.
    Yes the tunnel cover gets hot with vinyl or leather covering. Just like the seats.
    I keep a couple of towels in the trunk and throw over everything when needed. Especially before climbing back in for a drive. The snapless touneau cover also works well.
    Boyertown, PA
    What is this "snapless toneua cover" you speak of Paul? Tell me more!
    http://www.ffcars.com/forums/17-fact...s-tonneau.html
    http://www.ffcars.com/forums/138-har...illip-kay.html
    BTW, in my previous response about the transmission cover getting hot I was only talking about it while parked. Obviously the sun is still shining while driving. Ideally anyway. Probably gets a little warmer than carpet then too, but I haven't noticed it as a problem at all. There's apparently enough air movement to keep the temp down. Having driven mine now all this season with the leather cover, nothing about it would prevent me from doing the same again.
    Boyertown, PA
    awwww gee whiz Paul, here we go again........
    I had to ask, didn't I? You guys love spending my money. Phillip & Kay's cover is a no brainer.
    Yep, I'm not really sweating (no pun) the heat thing. Like you said, it can easily be managed with a cockpit cover/towels/park the car in the shade, etc. Black leather seats, black carpet, yadda, it's going to be hot. Not like I'm going to change gears at this point in the build and top the trans tunnel in carpet. I'm sticking to the plan!
    Thanks for the tip on Phillip & Kay's cover. Not the first time you have spent my money and I know it won't be the last!
