I'm test fitting the body this weekend so I can determine the vertical location of the dashboard. Finally. Been threatening this for a while. Whatever. According to the manual, I should put the weather stripping on the curved frame piece (top of dash) and the firewall. I know that many builders view the manual as a "suggestion" rather than gospel. So what do you think? weatherstripping and bulb seal prior to test fit, or just test fit without the padding? Thanks in advance! Of course, if you have any other body test fit tips, I'm all ears.
