To amplify on what Mike said, the speedometer is counting pulses from the speedo sensor in the transmission. You don't have to maintain any set speed, and you can speed up or slow down as you desire / the road dictates.
P.S. Bill, you're quite the lurker. Only 104 posts in 6 1/2 years? Wow!
MK IV Roadster #8631
