There are also some spacers to raise it up (at least for my TKO there were) and the actual urethane mount that go with it. I remember the spacers weren't mentioned in either the packing list or instructions, but when I fit it up I randomly remembered seeing them (and dismissing as extra parts) during my inventory, threw them in and they were the perfect height. Also, I had to wallow the slots on the bracket on either side out a bit to get it to fit the frame mount slots (they were a bit closer together) due to tolerance issues.
Darth
I am installing the same combo right now. My 700r4 trans came from the rebuilder with a mount attached to the tailshaft. It appeared too short. I bought another mount, basically identical, at my local speed shop. Each mount has three threaded holes. The mount from the speed shop also has two threaded studs with an allen hole in one side. I drilled two access holes in the back side of the upper mount and screwed the two allen studs through the first mount and into the second, where they bottomed out. Next I attached all of this to the trans and then lifted the tailshaft high enough to clear the mount you show in your picture. I had to file a radius into each round hole, toward the car centerline, in order to get the lower bolts I chose, to fit through. I used large diameter round washers to compensate for the oblong holes.I then slide the trans backward, using a scissor trans jack for support, until this taller mount setup would sit down on the mount you show. That is as far as I have got, but taking measurements form the engine block mounting holes to the transmission mating face, it appears I am almost exactly where I need to be. My block is a '64 283 GEN I motor with mods. It made 337HP on the dyno @ 5700 RPM. Steve Ashley Albuquerque New Mexico
