Results 1 to 4 of 4
Thread: Chassis number question
    Elk Grove, NorCal
    I received my 289 kit yesterday. The serial number engraved on the 2"x2" tube going across the car at the front of the cockpit reads F5R1009180RD. Everyone on the forum uses a 4 digit number. Do I use 9180 as my number?
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
    Quote Originally Posted by Vspeeds View Post
    Generally, yeah. I sometimes add the "RD" but anyone who's been around a while will know immediately it's a MKIV.
    Or is it? In your case, no! USRRC and Roadsters use the same chassis so they share Chassis numbers. Meaning 9180 is a USRRC but 9181 could be either a USRRC or a MKIV.
    CONGRATS by the way!
    Elk Grove, NorCal
    Thanks for the quick reply. Yes, I wasn't sure because of the shared chassis and if they differentiated the two.
    Vermilion,OH
    There is a vendor in the vendor area that embroiders shirts with your FF chassis number, mine is FF8955, and a cobra below it in the color similar to what your car will be. I had two long sleeve denim shirts done for my wife and I, nice work.
    We'll help you spend money on all sorts of things.
