I had a helping hand and got the Coyote set in the frame. I put it in without the trans or bell housing.
A couple of questions or request for pics. The dip stick just barely clears the foot box. Not having the trans to control the angle of the engine, I put a 3/4" block under the crank pulley and front cross member. This is another close clearance point. If anyone has some pictures of how much clearance, I should be seeing in these areas, big thanks.
Both motor mounts and alignment buttons are in place on the frame mounts. I did tighten the nuts on the mounts to keep the engine from getting into the boxes or frame.
