Hi Railroad.
In 2012 I mounted the ECU over top of the passenger footboard instead of the FFR suggestion at the time which was to mount it in the firewall. The bracket I fabbed is mounted on the outside of the 3/4" square steel support keeping the ECU out of the engine bay. This location is now the norm and FFR supplies the bracket. The main Coyote harness runs behind the firewall. Again, out of sight. The PDB is mounted under the center of the dash above the trans tunnel. It is hidden with a center console. The harness runs through the opening in the firewall at the far right side - passenger side. Again, out of sight. The harness from the ECU to the engine comes across the front of the engine. There was sufficient cable for O2 sensors. I had to pull the MAF sensor wires out of the bundle.
It worked well and was pleasing to the eye.
There is a member in Quebec (paquette173) who mounted his ECU in the void under the intake mznifolx. Not sure how that worked out.
