After getting the engine set in, I am trying to route the harness around the engine compartment.
There are excellent threads on the later model harness's, but mine seems to locate stuff at other locations.
The harness seems to locate the ECU up front between the rad and eng, right side. It looks like the O2 sensors will both be short. I have room to run the main harness through the valley under the intake.
I am hoping someone has run the early Coyote harness on a MkIV in a build thread or has some pics I could view.
My PDB has windows for diff circuits, ie fan, A/C, intercooler pump, etc. It may have LEDs to show good or bad fuses,,? It also does not use the heavy main power cable. It does have the HAAT cable, but it is about 10 ga.
The directions are clear, it is just the routing, I would like to see. Any other advise on this harness is welcome.
thanks,
