Results 1 to 22 of 22
Thread: battery location?
    battery location?
    what options are there for battery location?
    Louisville, KY
    I just received the front battery mount kit from Mark at Breeze. Very nice kit and puts the battery up front near the engine.
    FFR8551 289 FIA build in progress.
    North CT
    I got the FFMetal battery box in the trunk
    Copperhill, TN
    I used the Breeze option, works great. Keeps the cable runs short, easy to get to.
    my battery is currently in the trunk.
    Is it possible to make room and located it further into the trunk next to roll bar?
    Quote Originally Posted by tcsracing1 View Post
    Some builders added a drop box to the upper trunk shelf, to put the battery in. There was/is (?), a vendor making the boxes for that purpose.
    You could probably fit a smaller battery, on the upper shelf, on a battery tray, rather then with the provided battery box. This would allow you to lift it, and slide it out for replacement when required.
    Raleigh NC, OIB NC
    In the trunk on the upper shelf.
    Kevin
    MKIV #8234
    Here are a couple of pictures of the FF Metal trunk floor battery box I installed:
    Ditto on the location with Kevin; however, I did upgrade the battery box with one that I purchased from Speedway motors.
    https://www.speedwaymotors.com/Speed...Tray,3455.html
    I bent the upper tabs over 90 degrees, with a little Map Gas induced heat, and then had a friend Powder Coat it before bolting it in.
    On the passenger side foot box top.
    Senior Member dallas_'s Avatar
    Dallas, TX
    mine is down between the engine and front frame rail on the passenger side.
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    Home made front battery box for a group 51 size battery. Has no trouble starting my 302. Just a bit of angle iron, neighbors mig welder, hammer, saw , and some heavy duty self tapping bolts I found at tractor supply. Used the battery hold down that came with the kit (not pictured).
    2bking's Avatar
    Garland, Texas
    In the trunk using the dropped trunk space to slide the battery on its side into the space available over the pumpkin.
    King
    Raleigh NC, OIB NC
    Have a billet base built to match the bottom shape of the red top. Locks down with clamps built into the base.
    Kevin
    MKIV #8234
    Member dmoran's Avatar
    Crownsville, MD
    I went with the Breeze front mount. Very convienent and easy to work with.
    Mk4 Roadster #8843. Kit Pickup: 03/19/2016
    Roush Performance 331 SRXE Crate Engine, TKO-600, 3-link rear, 17x9 and 17x10.5 Halibrand wheels w/ Nitto NT05 tires
    Doug's Mk4 Build Thread - Annapolis, MD
    Be careful w/ the trunk boxes depending on what rear suspension you have. They don't all fit.
    Oct 2014
    I went with the Breeze kit. I like it!
    I have the FF Metals trunk battery box. Well made and fits perfectly.
    Jax Beach, FL
    FF Metals if you want the weight where the car needs it. I have had to access my battery precisely ZERO times in 3+ years, so not like it needs to be convenient. I did upgrade my cables in full disclosure.
    Northern VA
    Ffmetal here. Nice and out of the way!
    May 2016
    nice find godadgo!
    Leesburg, Va
    FFMetal Battery box. I also upgraded my battery cables. After 2k miles I have not once needed to touch battery. I do have a cockpit cutoff though and I have used it a few times.
    Doug
    FFR 7995
    347 SBF Prestige Mototsports, Moser 8.8 (3.31) 3 Link, TKO 600, Nitto 555s, 17" Halibrands, PS, AC, Heat, Color Redfire Pearl, with Wimbledon White Stripes
