Results 1 to 9 of 9
Thread: master list of Torque specs
    Has anyone compiled a list of all the various torque specs throughout the build manual?
    Feeling lazy and instead of making a list was wondering if anyone has ever taken care of it already.
    Fairfax Station VA
    I grabbed this off the other forum a couple of years ago. Truth in advertising: I haven't cross checked to ensure accuracy.
    Torque Specs according to FFR Build School at Mott Community College hand out material and documents
    Front suspension
    Upper control Arms adjustment bolts 60
    Upper control Arms mounting bolts 100
    Bracket (Spindle) 70
    Shock (bottom) 70
    LCA 110-150
    Shock Bracket (Lower Arm) 55-70
    Ball Joint (upper) 80-120
    Ball Joint (lower) 80-120
    Rear Suspension
    Upper control Arm to axle 70-100
    Upper control Arm to frame 80-105
    Lower Control Arm to axle bracket 70-100
    Lower Control Arm to frame 80-105
    Lower Control Arm Bracket to axle 90
    Shock Bracket, Lower 55-70
    Shock, Top 25-30
    Shock bottom 45-60
    Quad Shock bracket to frame 56-70
    Quad Shock to bracket 56-70
    Quad shock to axle 56-70
    Rear Suspension (3-Link)
    Pan hard Bar 250
    Upper frame mount 90
    Rear Suspension (IRS)
    Rear Axle nut 250
    Shock (upper/lower) 70
    Spindle attachment 100
    Driveshaft to center section 70-95
    Steering Rack/Shaft
    Steering Rack Bolts 30-40
    Tie Rod Ends 25-35
    Pillow blocks 20
    Exhaust
    Straight Pipe 35
    Engine/Transmission
    Transmission Mounts (Tranny to mount) 50-70
    Transmission mount (Mount to frame) 25-35
    Engine mount (Engine to mount) 35-60
    Engine mount (Mount to frame) 50-105
    Driveshaft bolts 70-95
    Lights/ Trim accessories
    Windshield 90
    Quick Jacks 60
    Body Bolts 20
    Miscellaneous
    Wheel lug nuts 80-105
    Pedal box (front plate upper) 35
    Pedal box (Frame down tube) 10
    Header to block 18-24 ft-lb
    Intake to head 18-20 ft-lb
    General Guidelines (Zinc Plated Hardware)
    Thread Size SAE Grade 5 (ft-lb) SAE Grade 8 (ft-lb)
    ¼-20 10 14
    ¼-28 12 16
    5/16-18 21 29
    5/16-24 23 33
    3/8-16 37 52
    3/8-24 42 59
    7/16-14 59 83
    7/16-24 66 93
    ½-13 90 127
    ½-20 101 144
    9/16-12 129 184
    9/16-18 144 205
    5/8-11 179 254
    5/8-14 202 287
    MK IV Roadster #8631
    cool thanks
    Lilburn, GA
    Coyote Torque specs. NOTE: Ford uses a lot of torque specs, PLUS an extra degree of turn after achieving the given torque.
    https://lmr.com/products/mustang-50-...r-torque-specs
    Jax Beach, FL
    I keep thinking I need to go through and make that list up rather than dig into the manual. Thanks for posting it.
    Engine specs are a whole different thing. Sometimes torque, degrees, or stretch.
    That appears to be a bad link. Would you mind trying again please
    Lilburn, GA
    CORRECTED LINK (looks the same... not sure why the first one doesn't work)
    Senior Member tonywy's Avatar
    Nanticoke, Pa
    Thx. I have my complete front suspension apart and this info will be very helpful in reassembling it.
    We we're supposed to torque the bolts????
    Haha just playing... This is a great list... Thanks guys.
