Thread: Clutch Cable Bracket
    Senior Member jwebb's Avatar
    Longmeadow, MA
    l-shaped bracket that comes attached to the clutch cable has vanished, anyone have a extra cable they would part with (cheap)? I'd hate to pay $41 & freight for another new cable..
    Northern VA
    I htink I have one with a bracket in the garage. I can check and send you a picture if that works. Will have to do tonight when I get home from work. Also, I took the bracket off mine and it seems fine.
    Why not just make a bracket for it, instead of replacing the entire cable?
    Use a piece of flat bar steel or aluminum, and a line clamp. Drill the appropriate size holes, bend to shape, attach the cable. Bob's your uncle..
    I threw out all my brackets. I never use them
    Windsor, CT
    I have a cable I removed when I converted to hydraulic.
    Windsor, CT
    Call me 860 604 7260
