Results 1 to 3 of 3
Thread: Gas tank parts
    Future Mk4 builder/owner
    Harleysville, pa (near Philly)
    Gas tank parts
    Looking for some parts for my gas tank, that have vanished. Can't find them and afraid may be MIA forever after I moved.
    What I'm missing:
    1)The rubber seal that holds the filler tube in the tank
    2) The vent valve and the rubber seal to hold it in the tank
    3) the hard line that connects to the tank and goes to the filter (about a foot long with those connectors on it.
    4) The 2 connectors that attach to the hose from #3
    What I have:
    The tank
    The tank cover
    The tank straps (missing the studs and bolts but those I can make/find if needed)
    Fuel filter and mount
    The Fuel level/float sender and seal
    The fuel pump arm and assembly that goes into the tank.
    If anyone has any of the above pieces I need that they may not have needed or used, please let me know. Thanks so much!
    I'm going to keep looking too, but I'm running out of areas they could be hiding. Thanks again everyone for looking!
    May 2016
    Lmr.com
    UPDATE, found all the parts in one of the last boxes i checked.
    ONLY NEED a fuel pump hanger assembly now.
    Have the in tank pump but the upper part of the hanger is all damaged. Leads for the in- tank pump are broken off.
    Anyone have one they didn't use, please let me know.
    Thanks.
