Results 1 to 3 of 3
Thread: Vinyl dash install
    Jun 2017
    Vinyl dash install
    I purchased the vinyl dash from FFR. Is it best to just temporarily suspend dash in place and wire gauges etc and wait til body is installed to screw it in place?
    Appreciate any advice.
    Thanks!
    There are only a few connections that actually attach the dash to the car. You can wire up most of it without the dash even being in the car. I ended up putting plugs on those few connection points so I could easily remove the entire dash by simply unplugging a few things and being able to take the dash completely away. The ignition switch I wired up but just unscrewed that bezel completely from the dash. No removable plug on that.
    Jun 2017
    Thanks��
