Results 1 to 6 of 6
Thread: Russ Thompson turn dignal and Diodes. Does anyone know the specific one to order?
    Accord NY
    As I understand it if I am using the RT turn Signal, Ron Francis harness, and a single throw double pole hazard switch from Factory 5 then I only need a diode between the VW and Bosch relay? If this is true what diode do I need to purchase?
    Thanks for the help
    Craig
    Nov 2012
    Tacoma, WA
    Listed here in the instructions
    Accord NY
    Thanks. Did not have that handy and wanted to order for the weekend. Thanks again.
    Senior Member Jdav's Avatar
    ATL GA
    As Radio Shack is no longer around, those part numbers may not do you any good
    I used these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    MK4 #9028 - Coyote - TKO600
    Accord NY
    Hi Jdav,
    These are the ones I purchased from Ebay, https://www.ebay.com/itm/5pcs-MCC-50...72.m2749.l2649 Will these work? Thanks for posting your link.
    Aptos, CA
    Quote Originally Posted by cfriedman67 View Post
    Hi Jdav,
    That's more than enough. You should have no problem.
    www.weendoggy.com/cobra.htm
