0
0
Russ Thompson turn dignal and Diodes. Does anyone know the specific one to order?
As I understand it if I am using the RT turn Signal, Ron Francis harness, and a single throw double pole hazard switch from Factory 5 then I only need a diode between the VW and Bosch relay? If this is true what diode do I need to purchase?
Thanks for the help
Craig
MKIV #9122 Ordered kit 5/24/17 received kit 8/11/17 MK4 Base kit +,First Start 4/7/18, First Go-Cart 4/22/18, In gelcoat, licensed and driving 8/11/18. Coyote gen2, T-56, 2015 IRS 3.31, 17" Halibrand replicas w/Nitto NT555 G2, Withby Motorcars power brake kit W/Wilwood pedals, 04 Cobra front brakes, 15 Mustang rear brakes with mods, power steering. Paint Jeff Miller Da Bat, Lexus Spectra Blue Mica W/Toyota Silver Sky Metallic strips. Build thread:
http://thefactoryfiveforum.com/showt...Paul2STL-Build
Thanks. Did not have that handy and wanted to order for the weekend. Thanks again.
As Radio Shack is no longer around, those part numbers may not do you any good
I used these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Hi Jdav,
These are the ones I purchased from Ebay, https://www.ebay.com/itm/5pcs-MCC-50...72.m2749.l2649 Will these work? Thanks for posting your link.
Originally Posted by
cfriedman67
That's more than enough. You should have no problem.
