'A-frame' ? I think I may have seen something like this in one of the boxes. Will check.
Thanks.
Martin
Thanks.
Martin
Also test fit your motor mounts to your engine block. I have a Dart 347 also and had to do some grinding on the motor mounts to get them to fit. I would not grind the block. Dart blocks have some webbing cast into them that interfere with the engine mounts. Good luck.
JR
Also I forgot to mention when you join your TKO600 to your engine you should dial indicate your bellhousing. Tremec requires this to be done to make sure the pilot shaft is within tolerance so you don't void your warrantee. Check American Powertrain's youtube video for how to do it. It's pretty easy but you will need a dial indicator and possibly some offset dowel pins.
JR
Hi Martin I got my eng/trans from Mike also, I called him to verify if he dial indicated the bell housing and he said he didn't. Call him though you'll have to remove the clutch also to position the dial indicator so you'll need the torque specs for the clutch and bell housing.
JR
Hi jrcuz.
Thanks, I just called him, and it isn't dialed. He mentioned that the quick time bellhousing is done so well that many times you won't have to do that.
If I am to remove the cover and the clutch -- I have no idea what I am doing here or how to measure it while putting it back together. kinda bummed about this discovery. Plus I don't have any of these measuring tools.
Martin
