Small error but nothing that would cause an interference issue. Now let's see if someone with a car like yours can provide a dimension from the same points.
Adjustable LCAs will allow you to adjust pinion angle without causing the banana bracket to hit but it will shorten your wheelbase a bit. Not sure if that would create another problem or not. Maybe one of the guys who has a car like yours has an opinion.
