Thread: Tail lights
    May 2016
    North of sacramento Ca.
    Tail lights
    How did you wire the tail lights(marker-turn-brake-hazard)?
    wire up like in wiring diagram. The tail light circuit, brake/turn signal are same wire.
    Oct 2014
    Mendon, MA
    The wiring diagram is confusing I will admit. The purple wire is the one that is not used on a Hot Rod. The turn signal wires are integrated as Brake & Turn signal together.
    SMG Motoring Inc.
    Custom Performance Vehicles
    www.smgmotoringinc.com
    www.facebook.com/smgmotoring
    My harness has 4 wires on each side for taillights, tan, black, purple and white/yellow. My LED taillights that came with the car have 3 wires to an 1157 male socket. Neither of the two manuals explain this. WTF
    Senior Member TomH33's Avatar
    Nov 2016
    Parker,CO
    The only info I could find on wiring 33 tail lights is on pg 34 of the "Chassis Wiring Harness" booklet. Towards the bottom is Hot Rod says white ground, Black tail lights and red turn signal and brake lights. I just found this myself. I don't have the body on yet but I wanted to know if all wires were as they should be. worked fine for me.
