0
0
Some of the guys made a seat plate welded in the frame to fix that sin of the design. You can just bolt thru that (not sanctioning body approved). I think I ran mine back to one of the diagonals and drilled through the tube. 3/8" grade 8 is about as big as you can get through those smaller tubes. Use hardened washers and Nyloc nuts.
