I will generally start at the center then work outward alternating back and forth. You're going to find it impossible to get a torque wrench on them so just try to give them all a consistent "oomph" (that is a well know engineering spec). You need to go back through and snug them after a couple of heat cycles and if you're using locking bolts don't engage them until you've done so.
