Thanks Thanks:  115
Likes Likes:  176
Page 10 of 10 FirstFirst ... 8910
Results 361 to 388 of 388
Thread: John’s Mk4 Build Thread - Winter punch list
  1. #361
    Oct 2021
    Sarasota, FL
    John,
    Do you mind saying which mounting system you bought and magnetic gauge.
    Bill
  2. Likes John Ibele liked this post
  3. #362
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by maclonchas View Post
    John,
    Bill
    Hey Bill, happy to help. I think this is what you're after, but chime in here or PM me if I'm off base:
    Longacre 78260
    Zackman Scientific ZAWG001
    Happy building!
  4. Thanks maclonchas thanked for this post
    Likes maclonchas liked this post
  5. #363
    Dec 2021
    Flower Mound TX
    I used similar items from Amazon that worked well.
    To get the caster accurate you need turn plates like these.
  6. #364
    Oct 2021
    Sarasota, FL
    Sep 2011
    Minneapolis, MN
    I used the poor man’s route (couple layers of poly with some chassis grease smeared in between). Gets you close … but I don’t know how close. Mine will be dialed in by a local speed shop, if I were dialing things in or doing it regularly I would definitely spring for the plates.
  8. #366
    Jun 2023
    CT
    I am apparently many years (a decade?) late to the party, but as an asipiring builder (hopefully 2024) I can not overstate how much I enjoyed reading through your thread. From its pure entertainment value, down to those great little build ideas and nuggets, I throughly enjoyed the time spent reading! I’m so happy for you that you are finally able to enjoy your project out on the open road and can’t wait to see what the “final” product looks like after the body receives as much love and attention as the chassis. Bravo!
  9. Thanks John Ibele thanked for this post
  10. #367
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by JayOH View Post
    Wow, what kind note, JayOH! I'm so glad you found it at least somewhat helpful, and when not that, at least hopefully entertaining. I do have a bit of loopy sense of humor at times, so am always conscious of the potential of entertaining no one but myself (and try to avoid that when possible). But the build project is so big, and for me full of so many unknowns (just about everything, to start with), that at least for me it was important to approach it with my sense of humor intact.
    I guess one big benefit of being late to the party is reading the build thread from beginning to end without needing a 10-year attention span. You may be the first! So many fine builders and advice-givers have come and gone in that time, and I couldn't have completed this project as successfully without them. Fortunately, many of them still contribute their free and knowledgeable advice. And new builders will always find their own fellow builders going through the journey at the same time.
    It has been an immensely rewarding project. The appearance of the completed car is something you can fully predict (other than color, I suppose). The things that are less certain relate to the driving experience, and I couldn't be happier with the combination of careful choices and maybe some luck that resulted in the completed car sitting in my garage. While I still plan to try autocross, this was going to be mainly a street / cruising machine, and as I got further into the build I continued to make choices best aligned with that in mind. For me, anyway, the biggest contributors to a car that drives pretty much like my daily driver were these:
    • IRS ... way more forgiving and comfortable than I ever expected. Going over bumps, no drama, and not even particularly stiff when combined with the standard roadster seats.
    • Cam ... pretty mild, and while my 347 makes 420 HP up top, I'm hardly ever going to be spinning up there. Most importantly it's very friendly down low, pulling happily from 1400 rpm, so I can putt through my neighborhood in 4th if I care to, and not tick anyone off with the noise. But lights up like it should when you get into the throttle.
    • T5 with taller 1st gear and tallest (0.63?) overdrive. Easy shifting, can handle all the torque I plan to give it, geared so that it settles down to a pleasant burble at cruise. Lots of happy cruising.
    • Power steering ... wouldn't ever go another direction. You give up nothing, including road feel, responsiveness, quickness in autoX. Plus, you get the stability you want and are used to on the highway.
    • Clutch ... I consider this a big drivability issue. I'm happy with my choice but I think I probably could have done better. It's not bad by any means, but is stiff (cable actuation) and bites pretty quick. Will be much better when I get the last minor stumble out of my Sniper tune.
    • Brakes ... this is one I would do differently next time and go the Wilwood route, but the fact is, I have absolutely nothing to complain about with the manual kit brakes. Predictable, plenty of stopping power, no fade, they need more pressure than power but that's just fine with me.
    Other engine, drive train, and suspension choices were less important for me. Controls were less important also, although having as much as possible like your daily driver still makes a difference. #1 would be having the gauges exactly where I want them and can see them. I spent plenty of time on that when laying out my dashboard. Second would be having the RT turn signals. My console cubby is very useful and practically stuffed on every drive. I don't have a rear cubby, which makes this a must-have for me.
    Once again I've wandered well off the topic of a simple thank you, so I may as well combine this with an end of driving season update...
    I gradually increased my sphere of confidence in driving the car through the summer, and the miles kept adding up. It was great to have one season in gel coat, when driving in the 'bug' hour just after sunset didn't matter a bit. I did the first oil change at 600 miles, and the magnetic plug had only a smudge about the size of a small pea ... wiped out on a shop rag there were not detectable bits in there, so everything seems fine. I didn't bother to cut the oil filter to do a deeper dive. I kept my commitment to myself and learned everything I could about tuning the Sniper. After 10 tunes I know plenty more, but can also see there will be items a pro can do better and way faster, so a professional tune is somewhere in the cards.
    I finished up the driving season with a cruise down the Mississippi on the Wisconsin side of the river, passing 1000 on the odometer along the way. I headed down the East bank to Maiden Rock, then back up to Red Wing, then picked my way on back roads up into the Twin Cities. The car behaved well: comfortable seating position, legs didn't get tired, and the car just likes to cruise. So much fun rowing through the gears when you get into a town or hit a stop sign. And ... who'da thunk ... seems to pass pretty darn well on two lane roads. I've got one thing that needs to get dialed in (or out). When I lift in a corner, I can feel the car moving towards oversteer, so still reminding myself to stay way away from the margins, and keep my inputs nice and smooth. I'll get my alignment done professionally, and then get my sway bars sorted and then should be good to go.
    And I think for this season, that's pretty much it. Such a rewarding project, with more to come. It's not graduated. But for now, time to put the car to bed until Kleiner comes calling, and the car should be able to welcome in the 2024 driving season wearing a new color.
    Happy building, all! Enjoy the journey, and remember - put down the tools and back away from the car when needed. With a project this big, we all have our moments. Cheers -- John
    Untitled by John Ibele, on Flickr
  11. Likes JayOH, 460.465USMC, cc2Arider liked this post
  12. #368
    Senior Member buttsjim's Avatar
    Apr 2020
    Congratulations on a beautiful build! I look forward to seeing it after paint. And, that last picture you posted is a great motivator for me!
  13. Thanks John Ibele thanked for this post
  14. #369
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by buttsjim View Post
    Thanks, Jim - and yeah, the picture pretty much says it all. I can't believe how enjoyable cruising on an open road in an open top car can be. Why didn't I know this? A Prius is my daily driver. 'nuf said.
  15. #370
    Oct 2020
    Albany, NY
    John, have you decided on the color yet?
    Build Thread https://thefactoryfiveforum.com/show...been-delivered
  16. #371
    Sep 2011
    Minneapolis, MN
    Hey Jesse! Still keep coming back to the blue family, but other than knocking out any truly dark blue, I haven't nailed it down. It will be blue, and it will have stripes, probably closely matching the Halibrand wheel color. I plan to have the rollbars painted in that same color. Beyond that ... could be anything from ice blue or silver blue all the way to a dusty blue. Current inspirations are below. But boy, I've already learned to please only myself on this topic. Introduced the topic of color at at large extended family event, and you would've thought I was telling people who they should vote for in the next election. Crazy, won't do that again.
    Top Contender: Mazda Eternal Blue Mica:
    Mazda Eternal Blue Mica by John Ibele, on Flickr
    The old school version - CSX2195 in Guardsman Blue:
    CSX2195 Guardsman Blue by John Ibele, on Flickr
    KDubU's combo of Viking Blue and Wimbledon White is great:
    Viking Blue and Wimbledon White by John Ibele, on Flickr
    Frost Blue Metallic 1959 Corvette:
    Frost Blue Metallic 1959 Corvette by John Ibele, on Flickr
    Mid-way between those and ice blue - Suzuka Blue Honda S2000:
    Suzuka Blue Honda S2000 by John Ibele, on Flickr
    Austin Healey 100-4 in Ice Blue Metallic:
    Austin Healey 100-4 in Ice Blue Metallic by John Ibele, on Flickr
    Mustang Silver Blue:
    Mustang Silver Blue by John Ibele, on Flickr
    Those are the insprirations right now, we'll see where we end up. At some point you just have to make a decision.
  17. Likes zarnold liked this post
  18. #372
    Oct 2020
    Albany, NY
    Same, I told some friends I was considering a yellow and it got weird pretty quick. You are correct in that you are the only one that has to like it. I really like the clubhouse leader as well but they are all great choices. As an aside that 59 Vette is insanely beautiful.
  19. #373
    Senior Member 460.465USMC's Avatar
    Aug 2019
    Spokane, WA
    So many really nice choices in the blue family. How can you choose? Ditto on Jesse's Vette comment. Love that color!
    Coupe complete kit delivered: 4/22/24. Build Thread. Coyote. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
  20. #374
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by 460.465USMC View Post
    Yep, that Vette is a stunner. Also a good reminder to take the glamour shots of your car in the magic hour around sunset.
  21. #375
    Nov 2018
    Centennial, CO
    I like your taste in car color and cars, John. Remember, while it is true that it’s only you that has to like the color, there is also future you. Forget about it for a while and it will come to in a very convincing way.
    Bradley
    Bradley
  22. #376
    facultyofmusic's Avatar
    Feb 2021
    Sunnyvale, CA
    That golden-hour picture of the vette feels like a huuuuuuuge unfair advantage for Frost Blue Metallic. I wonder what the mazda eternal blue mica looks like under the same lighting conditions. :P
    Mk4 Roadster: Gen 3 Coyote, IRS, T56 Magnum. Build thread here.
  23. #377
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by GTBradley View Post
    Bradley
    Thanks Bradley, yeah, pretty much settled on some shade of blue, and when it comes time the choice'll become clear.
    Quote Originally Posted by facultyofmusic View Post
    Dan! I do like that, and found the paint code. And yes, there's an evening cruise through the Mazda new car lot at some point coming up
  24. #378
    Sep 2011
    Minneapolis, MN
    Well, the temps are still stuck in the single digits here, the daily swimmers on Lake Nokomis quit punching a hole in the ice when it got to -10F, and the pond hockey tournament decided it would go ahead and put up a brick yard of 2 dozen ice rinks on the lake. So I guess we're having winter after all.
    But, the garage is heated, and I have stuff to knock off before the car goes to paint (granted, a few of these items are for after paint). If you can't drive the car I figure you can at least work on it.
    First on my list was to bite the bullet and drain the coolant so I could move the lower radiator tube and hose. It's a nice kit from Breeze, but I unfortunately hooked up the front hose so that there was interference between the front hose and the front sway bar. I figured that had to be dealt with. Better now:
    When I was driving last summer in gel coat I realized two things about the heater. It's great when you want it on. Second, you really want it to go fully off, which it doesn't really do without some work. Any air gap between engine bay and cockpit is going to dump a fair amount of heat onto you, so getting foam to fully seal between body and frame is the place to start. I took care of that, but then found that when you have a heater, hot air still wants to come through the vents even when the heater is 'off'.
    First I put in a full heater bypass valve, since the kit-provided valve looks like it still allows some coolant to flow through. I don't know that the full bypass valve helps a ton but I figured it couldn't hurt and would at least eliminate this source of heat.
    I'm celebrating that item as the one and only 'one hour job' that ever turned out to be actually a one hour job.
    Even if no coolant is flowing, though, the engine bay still wants to push its warm air through the vents when you're moving. So there will still be warm air blowing through the vents unless the vents themselves are completely closed.
    The Vintage Air 'Globe' style vents kinda have a closed position, but there's almost 1/16" around the outside of the globe when they're positioned that way:
    I ordered Vintage Air #499193 to get a better seal when closed. They're nice enough pieces, not something you'd find in a BMW but certainly OEM quality, and better than the globe pieces in terms of fit / finish in addition to seal. Hopefully that helps cut down on the unwanted hot air during those precious few MN summer driving months.
    Next up is getting the radiator guard (coarse SS mesh screen in a frame) back from the powder coater and back in place. Should be able to get to that in a few days.
  25. Likes Gbeck, 460.465USMC, Ted G liked this post
  26. #379
    Aug 2019
    Spokane, WA
    Quote Originally Posted by John Ibele View Post
    That, my friend, is a rare bird. Not sure if I can count more than one or so during my build.
    Speaking of a heated garage, nice to see you're getting to your punch list. Checking off those little nagging items brings outsized satisfaction IMHO. Was hoping to tinker on mine during off-season (AKA WINTER!) as well, but I'm framing/insulating/paneling/painting a "new" garage space (we moved). Can't wait to get some real garage time in again. Enjoy!
  27. #380
    Sep 2011
    Minneapolis, MN
    The radiator screen is back from powder coating and in place. It's stainless mesh from Pegasus Racing, framed by aluminum strips from the local Ace. Another Paul B. idea, if I hadn't mentioned that. I used nylon standoffs to keep it away from the raised sides of the radiator. It should allow me to fit my side aluminum pieces underneath when I get them fit and powder coated.
  28. Likes BRRT, Ted G, zarnold liked this post
  29. #381
    Sep 2011
    Minneapolis, MN
    Two more items got knocked off the winter punch list ... which is a good thing, since winter here in MN seems quite a bit shorter these days. They had a huge polar plunge event in the lake across the street last weekend, and the big day had a high of 70F. So cruising and new tunes on the Sniper are already competing for available time.
    Trunk and trunk lights: got the hinges powder coated, with barely any room to spare in my PC toaster oven.
    After spending quality time getting the trunk gapped correctly once again, I got the wire loom and gasket put in place and it looks pretty tidy.
    Thanks to Matt Glaser I have a section of LED strip encapsulated with silicone bumper which should make for a good trunk light.
    I decided not to run dedicated wiring for the trunk light, and instead tapped off the wires going to the license plate light. With this setup, the trunk light will go on whenever the parking lights are on. I still needed a tilt switch so the trunk light would always be off in the closed position ... current capacity is not usually posted for the cheapie switches that are readily available. My first choice was a real winner capable of ... 20 mA. So after debating adding a relay just 'cause it was handy, I looked a bit more and found this tilt switch from Digi-Key.
    Overkill, but that's fine. Rated for 1A at 12V, and I won't use more than 0.25A for my 54 LEDs. I mounted it on the aluminum access plate inside the trunk, where it's accessible but not visible.
    Gotta keep pushing through those last items. The call from Jeff should be coming soon.
  30. Likes Mike.Bray, 460.465USMC liked this post
  31. #382
    Dublin, OH
    might want to put the seam of your trunk seal at the bottom rather than the top of your opening.
  32. Thanks John Ibele thanked for this post
  33. #383
    Sep 2011
    Minneapolis, MN
    Good call! Although that’s probably not the only mistake I can count on Jeff to fix when he’s working his magic. Thanks for looking out for me, always appreciated.
  34. #384
    Jan 2020
    Twin Cities, MN
    Lights look great John! Did you use the crimps or attempt to solder? I've done both and probably will stick to crimps from now on for the LEDs anyway. Also I don't believe in overkill! If you take a trip and get caught out in the dark you can find what you need.
    Mark IV, 302 Based 347, TKx, Four link w/3.55, coil overs, PS, 4wheel Willwood. Dark Blue w Black/Red stripes, Saddle Interior, Blacked out chrome.
    Kit Ordered 4/18/2022
    Kit Delivered 2/20/2023
  35. #385
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by mrglaeser View Post
    Hey Matt! Solder here ... with painter's tape holding the strip on the bench and then tape holding the wire in place on the contact it was pretty easy. Then shrink tubing over the whole thing for strain relief.
    Thanks for the materials! (You have 246 LEDs left )
  36. #386
    Sep 2011
    Minneapolis, MN
    Next up on the winter punch list (which got a boost when winter decided to finally show up): wipers. I had a go at this earlier in the build, but just didn't like the end result, and by the time I was done "blueprinting" (read: trashing) my gearboxes, I was committed to ordering a new pair. Live and learn, and this wasn't that painful.
    I determined at the end of all that tweaking that the problem was really the aluminum tubing that came with my (vintage 2012) kit - 3/8", not 5/16", which is really what the gearboxes fit best with. For that matter, so does the cable. So I ordered new gearboxes and picked up some of the coated steel 5/16" tubing from AutoZone, and started over.
    First thing I noticed is that my new gearboxes had a longer shaft than the old ones. Not a bad thing; it avoids any interference of the gearbox with the body when the gearboxes are installed. However, I didn't have a handy way of getting the gearboxes to maintain the proper angle with respect to the body. I picked another bright idea from edwardb, and cut some square aluminum channel at the proper angle to attach to each gear box. Epoxied in place they look like this:
    This time around the alignment of the cable exiting the flared 5/16" tubing and into the gearbox was perfect - no 'adjusting' needed. When you're flaring the tubing, don't forget to put the wiper motor ferrule on the PS side tubing before doing the second flare! Ask me how I know. (And by the way, weren't these kinds of mistakes supposed to taper off near the end of a build?) No worries. Tubing is cheaper than my time, and I'm cheap. And any day in the shop is good day.
    After getting the ferrule properly located on the second piece of PS tubing, I liberally brushed chassis grease on the cable, installing each piece of the wiper assembly as I went. I found that the nuts that clamp the gearbox around the tubing are best left only hand tight (with a drop of blue Loctite to keep them from spinning off). For me anyway, it kept the cable well engaged with the gear, but allowed enough play to provide really smooth motion.
    I cut some gaskets for both the bottom and the top of the wiper assembly where it touches the body. This also seems to keep things at the right angle and solidly in place when tightened up.
    And the end result is: ... finally, something I can count on in the rain, if I can't count on staying out of the rain. I can run the wipers on a dry windshield on low speed and nothing stalls, there's no noise, just the hum of the motor. It can be done.
    On to the next winter punch list item ... side louvered vents. I didn't like the kit vents. I figured I'd order the assembled vents, but they were on back order. I waited, and waited, and then after reading more about the assembled vents, decided I didn't like those either. Actually, that's not quite true, they're just fine. But in my eager enthusiasm to get the body ready, I did the vent cutouts based on the measurements in the manual, instead of actually waiting for the assembled vents to show up. And the measured cutouts as stated in my manual are not a great fit for the assembled vents.
    After some more reading, found these guys mentioned: Roadster 'Oversize' Side Vents
    I like them. They're just a bit larger than the cutouts I already have in the sides of my roadster, and the center fin doesn't look too busy to me. I couldn't find any photos of them installed ... will post pictures when they're in hand.
  37. #387
    Sep 2011
    Minneapolis, MN
    I'm continuing to pick off items on the winter punch list while I wait for the call from Jeff. I waited forever for the assembled louvers to get back in stock at FFR, since I wasn't really keen on the kit-provided engine bay louvered vents. Problem is, I had already done my body cutouts, which don't fit the assembled louvered vents all that well. Oops, shoulda caught that one with more reading. In reading up some more and trying to figure out best options, I found a thread in which mentioned this option. I couldn't find any photos of them installed, but figured I'd give it a try.
    They need a slightly larger opening, 5-1/2 high by 8" long. The angle of the parallelogram shape is almost exactly the same as is called for by FFR for the side cutouts. The vents come unassembled and flat, so there's some work required to get them into finished shape. The cut edges are very rough, so you'll need to either grab your favorite Dremel accessory or some hand files to round the edges of all the fins. In other words, forget about the '5 minute assembly time". I've got some sharpie marker lines on the finished vent ... I plan to cut out the relief (left line) to allow more front-to-back positioning capability when I place the vent. Also, you don't have to make the vent as long as called for (right line).
    As delivered and after blueprinting / assembly:
    When I enlarged the cutouts I used the 'tight' (small radius) corners exactly matching the radius of the cuts on the vents, but that looked too sharp. I lengthened the cutouts on the car slightly to allow for a larger radius corner, which look just right. I'm happy with the choice. They don't look noticeably larger when installed, and they're sturdy and handsome. And - the initial motivator - I've got vents which are a good match for my cutouts now.
  38. Likes 460.465USMC liked this post
  39. #388
    Sep 2022
    Looks good John
    Craig C
