6
Seasoned Citizen
Originally Posted by
Arm7419
NAZ
Braille G30. Expensive. Had it about 6 years now.
Thanks! Boy they are proud of them but they seem to have good reviews and the weight savings might be worth the $$. I like that discharge curve -- similar to what I see in other lithium batteries.
33 Hot Rod Super Pro Drag Racer Build:
33 HR NHRA Cert Roll Cage Build
