Thread: 5mm fuel pump bolts
    Apr 2018
    League city, Texas
    5mm fuel pump bolts
    I’m dedrick from Houston building my first ffr 818c. I can not locate the 5mm bolts that FFR says is included. My question: can anyone give me more information on these bolts do I can go out and buy some to keep my build moving?
    Thanks in advance
    Atlanta, GA
    Quote Originally Posted by Dkelly View Post
    Thanks in advance
    FFR uses different bolts than the Subaru fuel pump bolts?
    Apr 2018
    League city, Texas
    My donor used nuts. The studs are part of the honor tank. The documentation identifies 5mm bolts that are supplied but I have not located them.
    Banned
    Assuming you're talking about the ones that go around the flanges on top of the tank, they came in a small bag attached to the FFR fuel tank if I recall correctly. They were not in the pre-packaged nuts and bolts.
    They are very small silver flange heads, and it's quite possible they fell off somewhere between the fuel tank manufacturer, factory five and your garage.
    Apr 2018
    League city, Texas
    Extremely helpful response. I'll follow up with Factory Five and I have looked all over the box the tank came in and assumed I overlooked them in the fastener box.
    Thanks again Phil1734
    Mar 2015
    Houston, Tx
    I couldn't find them with my kit either.
    I ended up bailing and ordering a Boyd tank so it didn't matter to me in the end.
    Mine were inside the tank, I believe...
    Apr 2018
    League city, Texas
    I did not look inside. David from FFR sent me the specs. I bought them today and ready to install the tank now.
    Apr 2018
    League city, Texas
    Just so it’s out there the bolts are: 5m-0.8 x 10mm
